当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
The tray will partially pop out of the laptop.
Firmly pull the drive straight away from the laptop.
While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
Lift and remove the optical drive assembly.
It may be helpful to gently "rock" the drive assembly side to side to dislodge it from its recess.
For the rest of the guide, be careful to not touch any of the circuitry on the board as well as the laser lens!
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
