当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Loosen the two captive screws on the right hand side of the hard drive cover. The screws will remain attached to the cover.
Remove the hard drive by lifting it up vertically on the right hand side. There is usually a plastic pull tab to help. If this does not work, gently pry it out with a flat head screwdriver.
Remove the one screw under the hard drive. This will help release the motherboard for later steps.
这个步骤还没有翻译 帮忙翻译一下
Remove the screw above the RAM access cover that holds the CD drive in place. Then, slide the drive to the left out of the case. Be careful not to pull the front off of the tray itself.
Remove the three(3) screws along the edge that are revealed after removing the CD drive. These screws hold the top bezel to the bottom frame.
这个步骤还没有翻译 帮忙翻译一下
After taking out the three(3) screws, flip the laptop over so that the keyboard side is up.
Remove the center cable from its connector on the button panel. Then, gently release the friction locks that secure the left and right ribbon cables by pushing them away from their connectors. The ribbon cables will slip out of their connectors.
这个步骤还没有翻译 帮忙翻译一下
After completing step 4, flip the laptop over again, making sure the battery side is up. Remove the two screws securing the RAM shield to the lower case.
Lift and remove the RAM shield up from the lower case; The screws will remain captive within the shield.
Remove the black Philips screw marked with a Keyboard icon.
这个步骤还没有翻译 帮忙翻译一下
After finishing step 5, turn the computer over and gently lift the keyboard at the top corners, sliding it upward and towards the screen. The bottom tabs will slide out from below the palm rest and the keyboard may be turned over to reveal the connection cable.
Disconnect the keyboard ribbon cable (highlighted in red) from its socket on the motherboard.
这个步骤还没有翻译 帮忙翻译一下
The LCD needs to be removed to proceed. Start by disconnecting the marked cable from its socket and disconnecting the cables from their clips in the palm rest.
Proceed to pull the two WiFi antenna cables through the motherboard.
Remove the screws that hold each LCD hinge cover in place. There is 1 screw for each cover.
Gently pry each cover off its hinge.
这个步骤还没有翻译 帮忙翻译一下
Remove the final screw holding the motherboard in place. Then gently lift the motherboard up vertically.
Remove the two marked cables. These will be tight. Do not pull by the wires. Carefully wiggle the connectors only.
Remove the final data cable near the front of the system board. The motherboard will be free. Lift up and towards the left to remove from the base.
41等其他人完成本指南。
7条评论
i need a dv 6000 pavilon motherboard. what is the cost. reach me on obiomaokerej@gmail.com
New is about $300 depending on your specific model. You can find used ones at around $75-150 on ebay. I'd be happy to help you locate parts if you give me the exact model number
Goodday! When I turn on my dv6, the power button just blink light and the laptop go off. Pls what can I do
Hi, i need a new mother board form this model. Spar part number: 578378-001. Are you be able to tell me where I can buy it at lower price? I live in Italy.
