跳转到主内容
HP Pavilion dv4000 Heat Sink Replacement
你所需要的
  1. HP Pavilion dv4000 Heat Sink Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Heat Sink Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Heat Sink Replacement: 步骤 3 中的图像 1,1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Heat Sink Replacement, Heat Sink: 步骤 4 中的图像 1,1
    • Position laptop with heat sink compartment facing you.
    • Locate the one 2x5 mm Torx screw.
  5. HP Pavilion dv4000 Heat Sink Replacement: 步骤 5 中的图像 1,1
    • Remove the one 2x5 mm Torx screw securing the thermal cover with a #6 Torx screwdriver.
  6. HP Pavilion dv4000 Heat Sink Replacement: 步骤 6 中的图像 1,2 HP Pavilion dv4000 Heat Sink Replacement: 步骤 6 中的图像 2,2
    • Lift thermal cover to reveal heat sink.
    • Remove and set aside thermal cover.
  7. HP Pavilion dv4000 Heat Sink Replacement: 步骤 7 中的图像 1,2 HP Pavilion dv4000 Heat Sink Replacement: 步骤 7 中的图像 2,2
    • Locate the four screws on each corner of heat sink.
    • Unscrew the four 2x12 mm screws with a #00 Phillips screwdriver.
  8. HP Pavilion dv4000 Heat Sink Replacement: 步骤 8 中的图像 1,2 HP Pavilion dv4000 Heat Sink Replacement: 步骤 8 中的图像 2,2
    • Grab sides of heat sink and carefully lift from compartment.
    • Due to adhesive bonding of heat sink to base, wiggling it side to side before lifting might help removal process.
  9. HP Pavilion dv4000 Heat Sink Replacement: 步骤 9 中的图像 1,1
    • To reapply thermal paste, check out iFixit's guide here.
结论
团队
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 558
