跳转到主内容
HP Pavilion 17-g192dx Cooling Fan Replacement
你所需要的
  1. HP Pavilion 17-g192dx Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion 17-g192dx Cooling Fan Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion 17-g192dx Cooling Fan Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
  2. HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
  3. HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 3 中的图像 1,2 HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 3 中的图像 2,2
    • Lift the battery up.
  4. HP Pavilion 17-g192dx Cooling Fan Replacement, laptop: 步骤 4 中的图像 1,1
    • Using the metal spudger, pry up the screw covers.
  5. HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 5 中的图像 1,1
    • Remove the fifteen 7mm screws holding the back casing on using the Phillips #00 screwdriver.
  6. HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 6 中的图像 1,2 HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 6 中的图像 2,2
    • Remove the 7mm screw holding the disc drive in place using the Phillips #00 head screwdriver.
  7. HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 7 中的图像 1,3 HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 7 中的图像 2,3 HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 7 中的图像 3,3
    • Using an iFixit opening tool, push the disc drive away from the outer case.
    • Once the disk drive is out far enough, it easily slides out.
  8. HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 8 中的图像 1,3 HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 8 中的图像 2,3 HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 8 中的图像 3,3
    • Remove the four 7mm screws holding the back resting plates on using the Phillips #00 screwdriver.
    • Using a metal spudger, lift up on the back resting plate until it pops off.
  9. HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 9 中的图像 1,2 HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 9 中的图像 2,2
    • Remove the two 7 mm screws behind the plate using a Phillips #00 screwdriver.
  10. HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 10 中的图像 1,3 HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 10 中的图像 2,3 HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 10 中的图像 3,3
    • Pry up on the case with an iFixit opening tool until you can feel a snap.
    • Pry around the remainder until you can separate the case from the keyboard with your hands.
    • Gently separate the two.
  11. HP Pavilion 17-g192dx Cooling Fan Replacement, Cooling Fan: 步骤 11 中的图像 1,3 HP Pavilion 17-g192dx Cooling Fan Replacement, Cooling Fan: 步骤 11 中的图像 2,3 HP Pavilion 17-g192dx Cooling Fan Replacement, Cooling Fan: 步骤 11 中的图像 3,3
    • Remove the four 2mm screws on the heat sink with a Phillips #00 screwdriver.
    • Remove the heat sink.
    • When setting the heat sink down, set it face down to avoid putting the thermal paste on the work surface.
    • When reinstalling the heat sink, be sure to clean the contact surfaces and reapply fresh thermal paste.
  12. HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 12 中的图像 1,1
    • Remove the two 5mm screws holding the fan in place using the Phillips #00 screwdriver.
  13. HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 13 中的图像 1,2 HP Pavilion 17-g192dx Cooling Fan Replacement: 步骤 13 中的图像 2,2
    • Unplug the cooling fan from the motherboard.
    • Remove the cooling fan.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 564
