简介
If you have a problem with the keyboard or trackpad and need to replace it, clean the dust in the system fan or gain component access this guide will show you how to remove the palmrest.
Guide notes
- While the keyboard cable is very long, the trackpad cable is substantially shorter. Use caution when disconnecting the trackpad connector.
- In order to disassemble this system, it needs to be disassembled top to bottom. Make sure the keyboard, trackpad and power button are disconnected before removing the palmrest.
- This is a difficult repair. It is a good idea to have a way to sort your screws as there will be two screws to remove the palmrest. This laptop uses multiple screw lengths.
Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
Remove the battery. Pull the battery forward and remove it from the laptop.
Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
With the palmrest screws removed, remove the screws under the optical drive. Use a Phillips #000 screwdriver.
Once the battery and optical drive are removed, remove the 11 screws that secure the palmrest.
This screw is hidden by a stick on cover. If lost, this is only cosmetic.
Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver.
Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
Use a plastic tool to remove the palmrest. Once all 3 sides are loose, disconnect the keyboard and trackpad. Flip the black plastic tabs on the connectors up to remove the cables.
Once the keyboard and trackpad are disconnected, the palmrest can be moved forward. If needed, a pry tool can be used.
With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up and remove the palmrest.
3等其他人完成本指南。
一条评论
My power button is bad and my mouse track stopped working. I couldn't find a replacement for it. What can I do?
