跳转到主内容
HP Pavilion 15-cd040wm CD Drive Replacement
你所需要的
  1. HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 步骤 1 中的图像 1,2 HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 步骤 1 中的图像 2,2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm CD Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion 15-cd040wm CD Drive Replacement: 步骤 2 中的图像 2,2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm CD Drive Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-cd040wm CD Drive Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-cd040wm CD Drive Replacement: 步骤 3 中的图像 3,3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm CD Drive Replacement, Battery: 步骤 4 中的图像 1,2 HP Pavilion 15-cd040wm CD Drive Replacement, Battery: 步骤 4 中的图像 2,2
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm CD Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion 15-cd040wm CD Drive Replacement: 步骤 5 中的图像 2,2
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: 步骤 6 中的图像 1,2 HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: 步骤 6 中的图像 2,2
    • Slide the CD drive out the side of the laptop.
结论
Brian Cornet
于10/21/19注册
316 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019 的会员
UMASSD-BOTVIN-F19S1G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 32
总计 571
