跳转到主内容
HP Pavilion 15-ba003ds Thermal Paste Replacement
你所需要的
  1. HP Pavilion 15-ba003ds Thermal Paste Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion 15-ba003ds Thermal Paste Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Thermal Paste Replacement, Disc Drive: 步骤 2 中的图像 1,1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Thermal Paste Replacement: 步骤 3 中的图像 1,2 HP Pavilion 15-ba003ds Thermal Paste Replacement: 步骤 3 中的图像 2,2
    • Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Thermal Paste Replacement: 步骤 4 中的图像 1,2 HP Pavilion 15-ba003ds Thermal Paste Replacement: 步骤 4 中的图像 2,2
    • Pull out the disc drive by hand.
  5. HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 步骤 5 中的图像 1,3 HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 步骤 5 中的图像 2,3 HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 步骤 5 中的图像 3,3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Thermal Paste Replacement, Thermal Paste: 步骤 6 中的图像 1,2 HP Pavilion 15-ba003ds Thermal Paste Replacement, Thermal Paste: 步骤 6 中的图像 2,2
    • Remove four 3mm Phillips #00 screws holding the CPU heatsink in place.
  7. HP Pavilion 15-ba003ds Thermal Paste Replacement: 步骤 7 中的图像 1,3 HP Pavilion 15-ba003ds Thermal Paste Replacement: 步骤 7 中的图像 2,3 HP Pavilion 15-ba003ds Thermal Paste Replacement: 步骤 7 中的图像 3,3
    • Gently wiggle and remove CPU heatsink.
    • Do not attempt to pull the heatsink away without having wiggled it, as it may cause damage to your motherboard.
    • Wiggle while holding the heatink on top of the CPU, not the fan housing.
  8. HP Pavilion 15-ba003ds Thermal Paste Replacement: 步骤 8 中的图像 1,2 HP Pavilion 15-ba003ds Thermal Paste Replacement: 步骤 8 中的图像 2,2
    • Generously apply the 99% isopropyl alcohol to your microfiber cloth.
    • Make sure that the thermal paste is completely wiped away and that the processor is dry
    • Apply a small pea sized amount of thermal paste to the processor.
    • Ensure that when you’re wiping away the old thermal paste that none of it falls onto the motherboard beneath it.
结论
2等其他人完成本指南。
Joseph Chia
于01/14/20注册
355 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 37
总计 2,234
