跳转到主内容
HP Pavilion 14-cf0014dx Motherboard Replacement
你所需要的
  1. HP Pavilion 14-cf0014dx Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Motherboard Replacement, Daughterboard: 步骤 5 中的图像 1,1
    • Remove the two 6.7 mm screws with a Phillips #0 screwdriver.
  6. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 6 中的图像 2,2
    • Unlock the ZIF connector with the tip of the spudger.
    • Remove the ribbon cable.
  7. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the daughterboard with a pair of tweezers.
  8. HP Pavilion 14-cf0014dx Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,2 HP Pavilion 14-cf0014dx Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the single screw securing the SSD to the motherboard.
  9. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 9 中的图像 1,3 HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 9 中的图像 2,3 HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 9 中的图像 3,3
    • Remove the two 4.2 mm screws with a Phillips #0 screwdriver.
    • Use a spudger to disconnect the fan connector from the motherboard.
    • Remove the fan from the laptop.
  10. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 10 中的图像 1,2 HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 10 中的图像 2,2
  11. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the sliding cable connector with a pair of tweezers.
    • Pull from the white plastic tab and not the cables to avoid ripping them.
  12. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 12 中的图像 1,3 HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 12 中的图像 2,3 HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 12 中的图像 3,3
    • Remove the 4.2 mm screw with your Phillips #0 screwdriver securing the Wi-Fi card.
    • Use tweezers to detach the coaxial cables from the Wi-Fi card.
    • Hold the tweezers closer to the metal pin to avoid ripping the cable and damaging the connector when removing the clip.
  13. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 13 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the 2.5 mm screws from the motherboard.
  14. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 14 中的图像 1,3 HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 14 中的图像 2,3 HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 14 中的图像 3,3
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • Do not separate the metal clamps (holding the chip) too much to avoid bending them.
    • The RAM stick will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
  15. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 15 中的图像 1,2 HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 15 中的图像 2,2
    • Unlock the ZIF connectors with a pair of tweezers.
    • Remove the ribbon cables by the blue tab.
  16. HP Pavilion 14-cf0014dx Motherboard Replacement: 步骤 16 中的图像 1,1
    • Remove the motherboard from the device.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 145
