跳转到主内容
HP Pavilion 14-cf0014dx Battery Replacement
你所需要的
  1. HP Pavilion 14-cf0014dx Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Battery Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Battery Replacement: 步骤 4 中的图像 1,1
    • Lift the battery up and out and remove it from the device.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Sam Cole
于10/25/21注册
813 声望
创作了7篇指南
团队
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S2G7
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 68
总计 1,111
