跳转到主内容
HP Envy x360 m6-w103dx Speakers Replacement
你所需要的
  1. HP Envy x360 m6-w103dx Speakers Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Envy x360 m6-w103dx Speakers Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Speakers Replacement: 步骤 2 中的图像 1,2 HP Envy x360 m6-w103dx Speakers Replacement: 步骤 2 中的图像 2,2
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Speakers Replacement: 步骤 3 中的图像 1,3 HP Envy x360 m6-w103dx Speakers Replacement: 步骤 3 中的图像 2,3 HP Envy x360 m6-w103dx Speakers Replacement: 步骤 3 中的图像 3,3
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Speakers Replacement: 步骤 4 中的图像 1,3 HP Envy x360 m6-w103dx Speakers Replacement: 步骤 4 中的图像 2,3 HP Envy x360 m6-w103dx Speakers Replacement: 步骤 4 中的图像 3,3
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Speakers Replacement, Speakers: 步骤 5 中的图像 1,1
    • Disconnect the connector on the left speaker by gently pulling on each side of the connector.
    • Do not pull directly on the wires.
  6. HP Envy x360 m6-w103dx Speakers Replacement: 步骤 6 中的图像 1,2 HP Envy x360 m6-w103dx Speakers Replacement: 步骤 6 中的图像 2,2
    • Unscrew the three 6mm screws using a #00 Phillips screwdriver, one on the right speaker and two on the left speaker.
  7. HP Envy x360 m6-w103dx Speakers Replacement: 步骤 7 中的图像 1,3 HP Envy x360 m6-w103dx Speakers Replacement: 步骤 7 中的图像 2,3 HP Envy x360 m6-w103dx Speakers Replacement: 步骤 7 中的图像 3,3
    • Remove each speaker one at a time.
    • Carefully remove the wire connecting the two speakers, which is tucked under small plastic hooks on the bottom edge of the device.
结论
Steven Ngo
于10/10/19注册
927 声望
创作了7篇指南
团队
Cal Poly, Team S12-G2, Regan Fall 2019 Cal Poly, Team S12-G2, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G2
4 名成员
创作了23篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 638
