跳转到主内容
HP Envy x360 15-bp143cl Fan Replacement
你所需要的
  1. HP Envy x360 15-bp143cl Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Fan Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Fan Replacement: 步骤 3 中的图像 1,1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Fan Replacement: 步骤 4 中的图像 1,1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Fan Replacement: 步骤 5 中的图像 1,1
    • Detach the tape securing the heatsink to the laptop.
  6. HP Envy x360 15-bp143cl Fan Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #1 screwdriver (PH1 bit) to loosen the four screws securing heatsink.
    • The screws do not detach from the heatsink.
  7. HP Envy x360 15-bp143cl Fan Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the three 4mm screws from the fan.
  8. HP Envy x360 15-bp143cl Fan Replacement: 步骤 8 中的图像 1,1
    • Detach the cable connecting the fan and laptop by pulling from the white connector.
  9. HP Envy x360 15-bp143cl Fan Replacement: 步骤 9 中的图像 1,1
    • Remove the fan from the laptop.
    • During reinstallation, be sure to remove old thermal paste on both the heatsink and CPU contact points. Then, reapply thermal paste using our How to Apply Thermal Paste guide.
结论
Spencer Berkins
于10/10/19注册
574 声望
创作了4篇指南
团队
Cal Poly, Team S12-G3, Regan Fall 2019 Cal Poly, Team S12-G3, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 605
