本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide is to be used in the case of a power supply that has begun to give out. Power supply failure can be recognized through symptoms such as slower run time, or issues with pace of processing,
你所需要的
Place computer with the screen down on a flat surface.
Push the two locking latches to the unlocked position.
Push the cover toward the top of the computer and lift up.
Press locking latch on the bottom of the base of the stand.
Pull the plastic cover off of the stand.
Use a Torx T15 driver to remove the four 10mm screws on the VESA mount cover.
Lift up on the VESA mount cover to remove it.
6等其他人完成本指南。
