当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Place computer with the screen down on a flat surface.
Push the two locking latches to the unlocked position.
Push the cover toward the top of the computer and lift up.
Press locking latch on the bottom of the base of the stand.
Pull the plastic cover off of the stand.
Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
Tilt stand and lift up to remove it.
Use a Torx T15 driver to remove the single 10mm screw on the back panel.
Pull the back panel toward the bottom of the device to remove it.
Use a Torx T15 driver to remove the four 10mm screws on the VESA mount cover.
Lift up on the VESA mount cover to remove it.
Disconnect the power supply's black and yellow cable from the motherboard.
Use a Torx T15 driver to remove the two 8mm screws on either side of the power supply.
Lift the power supply from the case to remove it.
取消:我没有完成这个指南。
6等其他人完成本指南。
与3其他贡献者
于10/01/15注册
1,071 声望
创作了4篇指南
徽章: 12
+ 9更多徽章
CPSU-MANESS-F15S1G24
4 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 52
总计 5,302
