跳转到主内容
HP EliteBook x360 830 G6 SSD Replacement
你所需要的
  1. HP EliteBook x360 830 G6 SSD Replacement, Unfasten the back cover: 步骤 1 中的图像 1,1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 SSD Replacement, Release the clips: 步骤 2 中的图像 1,2 HP EliteBook x360 830 G6 SSD Replacement, Release the clips: 步骤 2 中的图像 2,2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 SSD Replacement, Release the remaining clips: 步骤 3 中的图像 1,2 HP EliteBook x360 830 G6 SSD Replacement, Release the remaining clips: 步骤 3 中的图像 2,2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 SSD Replacement, Remove the back cover: 步骤 4 中的图像 1,3 HP EliteBook x360 830 G6 SSD Replacement, Remove the back cover: 步骤 4 中的图像 2,3 HP EliteBook x360 830 G6 SSD Replacement, Remove the back cover: 步骤 4 中的图像 3,3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 SSD Replacement, Disconnect the battery: 步骤 5 中的图像 1,3 HP EliteBook x360 830 G6 SSD Replacement, Disconnect the battery: 步骤 5 中的图像 2,3 HP EliteBook x360 830 G6 SSD Replacement, Disconnect the battery: 步骤 5 中的图像 3,3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 SSD Replacement, Disconnect the SSD cover: 步骤 6 中的图像 1,3 HP EliteBook x360 830 G6 SSD Replacement, Disconnect the SSD cover: 步骤 6 中的图像 2,3 HP EliteBook x360 830 G6 SSD Replacement, Disconnect the SSD cover: 步骤 6 中的图像 3,3
    • With your spudger, pry up on the tabs at the top and bottom of the SSD cover.
    • This will loosen the SSD cover enough for it to pop out from its tension clips.
  7. HP EliteBook x360 830 G6 SSD Replacement, Remove the SSD cover: 步骤 7 中的图像 1,2 HP EliteBook x360 830 G6 SSD Replacement, Remove the SSD cover: 步骤 7 中的图像 2,2
    • Lift the SSD cover off the SSD and remove it.
  8. HP EliteBook x360 830 G6 SSD Replacement, Unfasten the SSD: 步骤 8 中的图像 1,2 HP EliteBook x360 830 G6 SSD Replacement, Unfasten the SSD: 步骤 8 中的图像 2,2
    • Use your Phillips screwdriver to remove the 2.4 mm-long screw from the SSD.
  9. HP EliteBook x360 830 G6 SSD Replacement, Remove the SSD: 步骤 9 中的图像 1,3 HP EliteBook x360 830 G6 SSD Replacement, Remove the SSD: 步骤 9 中的图像 2,3 HP EliteBook x360 830 G6 SSD Replacement, Remove the SSD: 步骤 9 中的图像 3,3
    • Grip the edges if the SSD near the screw indent.
    • Pull the SSD straight out of its socket and remove it.
    • If the SSD feels stuck, wiggle it side to side as you pull.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
另外一个人完成了本指南。
Clay Eickemeyer
于09/19/22注册
96,090 声望
创作了466篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 30
过去 30 天: 99
总计 3,778
