跳转到主内容
HP EliteBook 8560w Hard Drive Replacement
你所需要的
  1. HP EliteBook 8560w Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP EliteBook 8560w Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out.
  3. HP EliteBook 8560w Hard Drive Replacement, Back Panel: 步骤 3 中的图像 1,2 HP EliteBook 8560w Hard Drive Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,2 HP EliteBook 8560w Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Make sure your device is powered off and its battery removed.
    • Remove the four M2.5x8mm screws with Phillips #0 screwdriver and lift up the panel to access your Hard Drive.
  6. HP EliteBook 8560w Hard Drive Replacement: 步骤 6 中的图像 1,3 HP EliteBook 8560w Hard Drive Replacement: 步骤 6 中的图像 2,3 HP EliteBook 8560w Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Slide the hard drive to the left and lift it to remove it.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 34
总计 1,641
