跳转到主内容
HP EliteBook 850 G3 Display Assembly Replacement
你所需要的
  1. HP EliteBook 850 G3 Display Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Display Assembly Replacement, Unscrew the bottom: 步骤 2 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement, Unscrew the bottom: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 3 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 3 中的图像 2,2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Display Assembly Replacement, Remove the battery screws: 步骤 4 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement, Remove the battery screws: 步骤 4 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Display Assembly Replacement, Lift the battery: 步骤 5 中的图像 1,3 HP EliteBook 850 G3 Display Assembly Replacement, Lift the battery: 步骤 5 中的图像 2,3 HP EliteBook 850 G3 Display Assembly Replacement, Lift the battery: 步骤 5 中的图像 3,3
    • Lift and pull the flap located at the top of the battery to remove it.
  6. HP EliteBook 850 G3 Display Assembly Replacement, WiFi Card: 步骤 6 中的图像 1,1
    • Flip the laptop over so the model stickers face the ceiling.
  7. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 7 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 7 中的图像 2,2
  8. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 8 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 8 中的图像 2,2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  9. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 9 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  10. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 10 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 10 中的图像 2,2
    • Slide out the WiFi card.
  11. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 11 中的图像 1,3 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 11 中的图像 2,3 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 11 中的图像 3,3
    • Disconnect the coaxial cables wires from the WiFi card.
  12. HP EliteBook 850 G3 Display Assembly Replacement, Fan: 步骤 12 中的图像 1,1
    • Gently unclip the plastic frame.
  13. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 13 中的图像 1,3 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 13 中的图像 2,3 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 13 中的图像 3,3
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  14. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 14 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 14 中的图像 2,2
    • Carefully remove the connector for the fan.
  15. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 15 中的图像 1,3 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 15 中的图像 2,3 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 15 中的图像 3,3
    • Carefully remove the fan and heatsink assembly from the laptop.
  16. HP EliteBook 850 G3 Display Assembly Replacement, Display Assembly: 步骤 16 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement, Display Assembly: 步骤 16 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the 7.7mm screw and six 5.8 mm screws from the corners inside the laptop.
  17. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 17 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the 5.7 mm screw under the plastic frame.
  18. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 18 中的图像 1,1
    • Use the opening pick to unplug the cable with the black tab on top.
  19. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 19 中的图像 1,3 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 19 中的图像 2,3 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 19 中的图像 3,3
    • Disconnect wire over gold tape and remove tape. You will have to peel the wire up to get to the tape.
    • The tape is not reusable.
  20. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 20 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 20 中的图像 2,2
    • Remove the coaxial cables from the wifi card and from clear plastic holds. Remove the black tape and slip out from black clip.
    • This tape is not reusable.
  21. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 21 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 21 中的图像 2,2
    • Open the top of the laptop and bend the hinges so that the metal bits in the corners will come up.
  22. HP EliteBook 850 G3 Display Assembly Replacement: 步骤 22 中的图像 1,2 HP EliteBook 850 G3 Display Assembly Replacement: 步骤 22 中的图像 2,2
    • Take the display assembly off.
结论
另外一个人完成了本指南。
Annabeth Grover
于10/10/19注册
922 声望
创作了5篇指南
团队
USF Tampa, Team S1-G1, Leahy Fall 2019 USF Tampa, Team S1-G1, Leahy Fall 2019 的会员
USFT-LEAHY-F19S1G1
4 名成员
创作了6篇指南
3条评论
looks like there are duplicate steps for cover removal.
Cody White - 回复
do tou have tuchscreen assenbly for same nmodel ??
shiva netra - 回复
do upu have couch scfeen assembly for this model ; hp elitebook 450g3
shiva netra - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 2,716
