跳转到主内容
HP EliteBook 850 G3 Battery Replacement
你所需要的
  1. HP EliteBook 850 G3 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: 步骤 2 中的图像 1,2 HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Battery Replacement: 步骤 3 中的图像 1,2 HP EliteBook 850 G3 Battery Replacement: 步骤 3 中的图像 2,2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: 步骤 4 中的图像 1,2 HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: 步骤 4 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Battery Replacement, Lift the battery: 步骤 5 中的图像 1,3 HP EliteBook 850 G3 Battery Replacement, Lift the battery: 步骤 5 中的图像 2,3 HP EliteBook 850 G3 Battery Replacement, Lift the battery: 步骤 5 中的图像 3,3
    • Lift and pull the flap located at the top of the battery to remove it.
结论
5等其他人完成本指南。
Annabeth Grover
于10/10/19注册
922 声望
创作了5篇指南
团队
USF Tampa, Team S1-G1, Leahy Fall 2019 USF Tampa, Team S1-G1, Leahy Fall 2019 的会员
USFT-LEAHY-F19S1G1
4 名成员
创作了6篇指南
2条评论
Thank you very much for this guide.
Geoff Taylor - 回复
When charging the charging indicator remain orange for hours and does not change.
Raymond Malken - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 105
总计 9,478
