跳转到主内容
HP EliteBook 1050 G1 Battery Replacement
你所需要的
  1. HP EliteBook 1050 G1 Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP EliteBook 1050 G1 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Be sure to power off and unplug your device before you begin your repair.
    • Close your laptop and turn it over so that the side without the HP logo is facing you.
    • Using the TR9 screwdriver, loosen the nine screws from the base of the device.
    • These screws do not come out. Instead of removing them, you should simply loosen all the screws and proceed to the next step.
  2. HP EliteBook 1050 G1 Battery Replacement: 步骤 2 中的图像 1,2 HP EliteBook 1050 G1 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the base by inserting the plastic opening tool into the slit between the two portions of the case and gently prying the metal cover away from the body of the device.
    • Slowly work your way around the edge of the base.
    • Lift the cover of the laptop off of the body of the device.
  3. HP EliteBook 1050 G1 Battery Replacement: 步骤 3 中的图像 1,3 HP EliteBook 1050 G1 Battery Replacement: 步骤 3 中的图像 2,3 HP EliteBook 1050 G1 Battery Replacement: 步骤 3 中的图像 3,3
    • Find the connector between the battery and the device. It is on the left-hand side above the battery.
    • Use the spudger to gently pull the corners of the connector away from the black housing.
    • Alternate working each corner to avoid damaging the connector.
  4. HP EliteBook 1050 G1 Battery Replacement: 步骤 4 中的图像 1,2 HP EliteBook 1050 G1 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the seven black 3mm Phillips #00 screws next to the M2x3 label along the edge of the battery using the Phillips #00 screwdriver.
    • There are arrows next to the labels that will help you identify the screws.
    • HP placed Threadlocker Blue Sealant around the screws to keep them from loosening, so be careful to not strip the screws. To avoid this, apply constant downward pressure on the screws during this step.
    • In this step, a JIS #00 screwdriver could be more useful than a regular Phillips #00 screwdriver.
  5. HP EliteBook 1050 G1 Battery Replacement: 步骤 5 中的图像 1,1
    • Grip the battery by the edges and lift it out of its housing.
结论
Jacob Osecheck
于04/15/19注册
279 声望
创作了2篇指南
团队
Cal Poly, Team S2-G10, Maness Spring 2019 Cal Poly, Team S2-G10, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G10
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 32
总计 1,838
