跳转到主内容
HP EliteBook 1040 G4 Motherboard Replacement
你所需要的
  1. HP EliteBook 1040 G4 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 2 中的图像 1,2 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 4 中的图像 1,2 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 5 中的图像 1,2 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Motherboard Replacement, SSD: 步骤 6 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the single 5 mm screw securing the SSD to the motherboard.
  7. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Lift the SSD up and out of the device.
  8. HP EliteBook 1040 G4 Motherboard Replacement, Fan: 步骤 8 中的图像 1,2 HP EliteBook 1040 G4 Motherboard Replacement, Fan: 步骤 8 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the two silver 5 mm screws surrounding the fan.
    • The top left screw may be hidden under shielding tape.
  9. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 9 中的图像 1,3 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 9 中的图像 2,3 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Remove the electrical tape to expose the heat sink screws.
    • Using the Phillips #0 screwdriver, unscrew the four screws securing the heatsink to the motherboard.
    • Carefully disconnect the pin connector by pulling it from its slot.
  10. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Carefully remove the wires from the clip to the left of the fan.
  11. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 11 中的图像 1,2 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Lift and remove the fan and heatsink assembly from the device.
  12. HP EliteBook 1040 G4 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the five black 4 mm screws securing the motherboard to the device.
  13. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 13 中的图像 1,2 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Using the same Phillips #0 screwdriver, remove the two silver 6.5 mm screws from the secondary fan placeholder.
    • Remove the fan placeholder from the device.
  14. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 14 中的图像 1,2 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Carefully disonnect the "Main" and "Aux" cables from the dual band wireless driver.
  15. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 15 中的图像 1,2 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 15 中的图像 2,2
    • Remove the ZIF connector from the bottom left of the motherboard by lifting the small grey tab, then pulling the connector out of the slot.
    • For more information on properly disconnecting and removing Zero Insertion Force (ZIF) connectors, please visit this guide.
  16. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Disconnect and remove the four ZIF connectors from the bottom middle of the motherboard by lifting the small locking tabs, then pulling the connectors out of their slots.
  17. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Remove the pin connector from the top right corner of the motherboard.
  18. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 18 中的图像 1,1
    • Remove the ZIF connector from the top right corner of the motherboard by lifting the locking tab, then pulling the connector out of the slot.
  19. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 19 中的图像 1,2 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 19 中的图像 2,2
    • Remove the pin connectors in the top right corner of the motherboard by lifting them straight up. The longer, top, connector has a pull tab connected to it to assist in pulling it out.
  20. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 20 中的图像 1,3 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 20 中的图像 2,3 HP EliteBook 1040 G4 Motherboard Replacement: 步骤 20 中的图像 3,3
    • Remove the RTC battery pin connector from the underside of the motheroard.
  21. HP EliteBook 1040 G4 Motherboard Replacement: 步骤 21 中的图像 1,1
    • Carefully lift and remove the motherboard.
结论
Ryan Cameron
于09/28/21注册
181 声望
撰写一个指南
团队
Clemson, Team 4-1, Hunter Fall 2021 Clemson, Team 4-1, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S4G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 48
总计 1,044
