跳转到主内容
HP Desktop 550-A39 Fan Replacement
你所需要的
  1. HP Desktop 550-A39 Fan Replacement, CPU Fan: 步骤 1 中的图像 1,3 HP Desktop 550-A39 Fan Replacement, CPU Fan: 步骤 1 中的图像 2,3 HP Desktop 550-A39 Fan Replacement, CPU Fan: 步骤 1 中的图像 3,3
    • Power down the computer and unplug all power cables.
    • Hold the power button down for 30 seconds after turning off the computer to deplete any excess power that may remain in the motherboard in order to avoid potential shock!
  2. HP Desktop 550-A39 Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the 10 mm flathead screw on the back panel with a flathead screwdriver.
  3. HP Desktop 550-A39 Fan Replacement: 步骤 3 中的图像 1,3 HP Desktop 550-A39 Fan Replacement: 步骤 3 中的图像 2,3 HP Desktop 550-A39 Fan Replacement: 步骤 3 中的图像 3,3
    • Slide the side panel back towards the back panel of the computer.
  4. HP Desktop 550-A39 Fan Replacement: 步骤 4 中的图像 1,2 HP Desktop 550-A39 Fan Replacement: 步骤 4 中的图像 2,2
    • Continue sliding the panel back until it is about halfway off the computer case, then lift it away from the computer.
    • Be sure to ground yourself sufficiently before moving any further to prevent the risk of an electrostatic discharge damaging your components.
  5. HP Desktop 550-A39 Fan Replacement: 步骤 5 中的图像 1,2 HP Desktop 550-A39 Fan Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    购买
    • Clean off any excess dust from the motherboard by blowing it off first and then wiping it off with a microfiber cloth.
    • Be gentle while wiping off the dirt. Don't put hard pressure on motions while attempting to clean as you may damage components.
    • You don't have to clean every speck of dust you see, only what is easy to clean!
    • Dust build up can cause the computer to overheat if not cleaned, which causes the fan to overwork and may damage the CPU fan. Over time, a fire may occur if dust is not cleaned as dust is flammable!
  6. HP Desktop 550-A39 Fan Replacement: 步骤 6 中的图像 1,2 HP Desktop 550-A39 Fan Replacement: 步骤 6 中的图像 2,2
    • Clean any excess dirt from the CPU fan.
    • Disconnect the CPU fan power cord by grabbing hard plastic cable connector and pulling it from the motherboard.
  7. HP Desktop 550-A39 Fan Replacement: 步骤 7 中的图像 1,2 HP Desktop 550-A39 Fan Replacement: 步骤 7 中的图像 2,2
    • Remove the four 15 mm screws from the fan with a Phillips #00 screwdriver.
    • Lift the fan up and away from the motherboard.
结论
另外一个人完成了本指南。
Ibrar
于09/19/20注册
292 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 39
总计 1,076
