跳转到主内容
HP Compaq Presario V3000 Palmrest/Touchpad Replacement
你所需要的
  1. HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
    • The battery may be warm or even HOT to the touch.
    • Locate the battery EJECT latch.
  2. HP Compaq Presario V3000 Palmrest/Touchpad Replacement: 步骤 2 中的图像 1,2 HP Compaq Presario V3000 Palmrest/Touchpad Replacement: 步骤 2 中的图像 2,2
    • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
    • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
    • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
  3. HP Compaq Presario V3000 Palmrest/Touchpad Replacement: 步骤 3 中的图像 1,2 HP Compaq Presario V3000 Palmrest/Touchpad Replacement: 步骤 3 中的图像 2,2
    • Pull the battery up and towards you to remove it from the laptop chassis.
    • Once the battery is out, you will be able to check the battery label for the replacement part number.
    • The part number is needed when purchasing a new battery.
  4. HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Keyboard: 步骤 4 中的图像 1,3 HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Keyboard: 步骤 4 中的图像 2,3 HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Keyboard: 步骤 4 中的图像 3,3
    • Use a Phillip's #00 screwdriver to remove all of the circled screws. Apply moderate pressure to each screw to avoid stripping it.
    • The three screws circled in red are 9mm Phillip's #00 screws.
    • The three screws circle in orange are 5mm Phillip's #00 screws.
    • The three screws circled in yellow are 6mm Phillip's #00 screws.
  5. HP Compaq Presario V3000 Palmrest/Touchpad Replacement: 步骤 5 中的图像 1,2 HP Compaq Presario V3000 Palmrest/Touchpad Replacement: 步骤 5 中的图像 2,2
    • Insert the rubber spudger gently below the edge of the keyboard.
    • Lift the keyboard vertically to detach it from the top assembly.
  6. HP Compaq Presario V3000 Palmrest/Touchpad Replacement: 步骤 6 中的图像 1,1
    • Flip the keyboard over. It may be easiest to hold it up in order to detach its wire assembly.
  7. HP Compaq Presario V3000 Palmrest/Touchpad Replacement: 步骤 7 中的图像 1,2 HP Compaq Presario V3000 Palmrest/Touchpad Replacement: 步骤 7 中的图像 2,2
    • Use your plastic spudger to unlock the two white sliding connectors located on the left and right side of the device by gently pushing them out.
  8. HP Compaq Presario V3000 Palmrest/Touchpad Replacement: 步骤 8 中的图像 1,1
    • With the white sliding connectors unlocked, gently grab the connector power cable and pull it out.
    • It should come out very easily; do not force it.
  9. HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Remove power button cover: 步骤 9 中的图像 1,2 HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Remove power button cover: 步骤 9 中的图像 2,2
    • Remove both the media button and power button cables from the motherboard.
    • Pull up on the edges of the power button cover with your fingers to remove it.
  10. HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Remove palmrest screws: 步骤 10 中的图像 1,3 HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Remove palmrest screws: 步骤 10 中的图像 2,3 HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Remove palmrest screws: 步骤 10 中的图像 3,3
    • Remove the six screws securing the palmrest to the base.
    • Remove all three covers, as well as the screw securing the optical drive. Pull the optical drive out.
    • Remove the single screw securing the hard drive caddy.
    • Remove the two screws from where the optical drive was.
    • Lift the hard drive caddy out of the laptop.
    • Remove the three screws from under where the hard drive caddy was.
    • Remove the single remaining screw holding the palmrest from the bottom.
    • Also remove the wireless antennas from the wireless card, as well as the wireless card.
  11. HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Remove cables, screen assembly, & palmrest: 步骤 11 中的图像 1,2 HP Compaq Presario V3000 Palmrest/Touchpad Replacement, Remove cables, screen assembly, & palmrest: 步骤 11 中的图像 2,2
    • Remove the single remaining screw securing the palmrest.
    • Remove all cables from the motherboard, and pull them from their clips.
    • Remove the five screws securing the screen assembly. Take care to support the LCD assembly as you unscrew it. Pull it up, then set it aside.
    • Use a spudger along the back of the computer to completely separate the palmrest from the base. Lift the palmrest up.
结论
3等其他人完成本指南。
Joseph Sctbunio
于09/23/17注册
7,527 声望
创作了42篇指南
2条评论
Thank you. I followed your guide successfully.
Trung - 回复
Hi,
Knowing About Websites & Manufacture Companies.
Thanks
NAFISA AZIZ - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 31
总计 1,524
