跳转到主内容
HP Chromebook 14-q063cl Display Screen Replacement
你所需要的
  1. HP Chromebook 14-q063cl Display Screen Replacement, Keyboard: 步骤 1 中的图像 1,3 HP Chromebook 14-q063cl Display Screen Replacement, Keyboard: 步骤 1 中的图像 2,3 HP Chromebook 14-q063cl Display Screen Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Flip the laptop upside down so that the bottom is facing upwards.
    • Use Phillips #0 screwdriver to remove nine 6.7 mm screws from the bottom panel.
  2. HP Chromebook 14-q063cl Display Screen Replacement: 步骤 2 中的图像 1,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 2 中的图像 2,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 2 中的图像 3,3
    • Use a metal spudger to pry the plastic covers off four additional screws.
  3. HP Chromebook 14-q063cl Display Screen Replacement: 步骤 3 中的图像 1,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 3 中的图像 2,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the four remaining 6.7 mm screws from the bottom panel.
  4. HP Chromebook 14-q063cl Display Screen Replacement: 步骤 4 中的图像 1,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 4 中的图像 2,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 4 中的图像 3,3
    • Turn the laptop upright.
    • Use an opening tool or picks to undo the clips around the perimeter of the keyboard assembly and separate it from the rest of the laptop.
    • Remove the keyboard assembly.
    • Disconnect the cable attaching the keyboard cable to the motherboard.
    • Use caution when removing the keyboard assembly so as to not break it or rip any cables or connectors attached to the board. Don't yank the keyboard assembly from the device.
  5. HP Chromebook 14-q063cl Display Screen Replacement, Display: 步骤 5 中的图像 1,2 HP Chromebook 14-q063cl Display Screen Replacement, Display: 步骤 5 中的图像 2,2
    • Use a spudger to remove the white adhesive covers from the left and right corners of the screen. Set them to the side.
  6. HP Chromebook 14-q063cl Display Screen Replacement: 步骤 6 中的图像 1,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 6 中的图像 2,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the two 2.9 mm screws that hold the screen frame in place.
    • There is one screw on each side of the bottom of the screen frame.
  7. HP Chromebook 14-q063cl Display Screen Replacement: 步骤 7 中的图像 1,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 7 中的图像 2,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 7 中的图像 3,3
    • Use a blue iFixit Opening Tool to pry off the screen bezel.
    • Flip the computer over so that the screen is facing upwards.
  8. HP Chromebook 14-q063cl Display Screen Replacement: 步骤 8 中的图像 1,2 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 8 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove four 2.9 mm screws that attach the screen to the top case of the laptop.
    • Do not remove the screws holding down wires as indicated by the orange circles.
  9. HP Chromebook 14-q063cl Display Screen Replacement: 步骤 9 中的图像 1,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 9 中的图像 2,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 9 中的图像 3,3
    • Use an opening tool or a black nylon spudger to lift the the screen away from the laptop.
    • Be careful not to damage the wire connected to the screen.
  10. HP Chromebook 14-q063cl Display Screen Replacement: 步骤 10 中的图像 1,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 10 中的图像 2,3 HP Chromebook 14-q063cl Display Screen Replacement: 步骤 10 中的图像 3,3
    • Use your hands to remove the tape that holds the connecting wire.
    • Remove the screen from the Chromebook.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 113
