简介
This guide will walk you through the replacement of a RAM that doesn’t hold enough storage in your HP Chromebook 14-ak041dx. The RAM is located inside the motherboard, so to replace the RAM, you will need to desolder it from the motherboard..
你所需要的
Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
Remove the heat sink from the laptop.
Remove the single 2.5mm Phillips #00 screw from the wireless card.
Gently pull the wireless card from the motherboard to remove it.
Carefully desolder the RAM using a soldering iron.
For soldering help, visit iFixit's How to Solder and Desolder Connections guide.
另外一个人完成了本指南。
