跳转到主内容
HP Chromebook 14-SMB SSD Replacement
你所需要的
  1. HP Chromebook 14-SMB SSD Replacement, Keyboard: 步骤 1 中的图像 1,1
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Lay the laptop down with the lower case facing up.
    • Remove eleven screws using a Phillips screwdriver.
    • Remove the two rubber stoppers, then remove the two Phillips screws.
  2. HP Chromebook 14-SMB SSD Replacement: 步骤 2 中的图像 1,2 HP Chromebook 14-SMB SSD Replacement: 步骤 2 中的图像 2,2
    • Flip the laptop over and open the lid.
    • Insert an opening pick into the seam between the keyboard and chassis.
    • Slide the opening pick a few centimeters along the seam to begin to release the clips.
    • Once there's enough space in the seam, insert an opening tool into the seam.
    • Pry around the entire perimeter of the keyboard until it fully releases.
  3. HP Chromebook 14-SMB SSD Replacement: 步骤 3 中的图像 1,2 HP Chromebook 14-SMB SSD Replacement: 步骤 3 中的图像 2,2
    • Lift the keyboard perpendicular to the laptop.
    • Flip up each of the the two black ZIF locking flaps that secure the keyboard and trackpad ribbon cables to their motherboard sockets.
    • Disconnect the keyboard and trackpad ribbon cables.
    • Remove the keyboard.
  4. HP Chromebook 14-SMB SSD Replacement, Battery: 步骤 4 中的图像 1,1
    • Use your fingernail or the flat end of a spudger to gently disconnect the battery connector from its motherboard connector.
  5. HP Chromebook 14-SMB SSD Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the three screws that secure the battery.
  6. HP Chromebook 14-SMB SSD Replacement: 步骤 6 中的图像 1,1
    • Lift the battery up and out of the chassis.
    • Take care not to scratch or damage the battery. Lithium-Ion batteries can be dangerous if punctured.
  7. HP Chromebook 14-SMB SSD Replacement, SSD: 步骤 7 中的图像 1,1
    • Remove the three Phillips screws that secure the motherboard.
  8. HP Chromebook 14-SMB SSD Replacement: 步骤 8 中的图像 1,3 HP Chromebook 14-SMB SSD Replacement: 步骤 8 中的图像 2,3 HP Chromebook 14-SMB SSD Replacement: 步骤 8 中的图像 3,3
    • Use your fingernails or the flat end of a spudger to disconnect the speaker and fan connectors from their motherboard sockets.
    • Flip up the black ZIF locking flaps of any ribbon cables connected to the motherboard.
    • Disconnect the ribbon cables.
    • Use your fingernails to disconnect the white connector on the underside of the motherboard.
  9. HP Chromebook 14-SMB SSD Replacement: 步骤 9 中的图像 1,1
    • Disconnect the two wireless card antenna cables.
    • Pull the wireless card directly out of its motherboard port.
  10. HP Chromebook 14-SMB SSD Replacement: 步骤 10 中的图像 1,2 HP Chromebook 14-SMB SSD Replacement: 步骤 10 中的图像 2,2
    • Pull the motherboard a few millimeters to the right to unseat the ports from the chassis.
    • Turn the motherboard over.
    • Remove the single Phillips screw that secures the SSD.
    • The SSD will flip up a few millimeters after removing the screw. This is normal.
  11. HP Chromebook 14-SMB SSD Replacement: 步骤 11 中的图像 1,1
    • Pull the SSD directly out of its motherboard port.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Cole Simpson
于02/19/25注册
275 声望
创作了2篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 39
总计 252
