跳转到主内容
HP 7 Plus 1302 Headphone Jack Replacement
你所需要的
  1. HP 7 Plus 1302 Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 2 中的图像 1,2 HP 7 Plus 1302 Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 3 中的图像 1,2 HP 7 Plus 1302 Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Headphone Jack Replacement, Battery: 步骤 4 中的图像 1,2 HP 7 Plus 1302 Headphone Jack Replacement, Battery: 步骤 4 中的图像 2,2
    • Push out the battery connector using the spudger.
    • Swing the battery connector clear of the connector socket.
  5. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Lift the battery from the device.
  6. HP 7 Plus 1302 Headphone Jack Replacement, Motherboard: 步骤 6 中的图像 1,2 HP 7 Plus 1302 Headphone Jack Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Pry the connector that attaches the front and back camera with a metal spudger.
  7. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 7 中的图像 1,2 HP 7 Plus 1302 Headphone Jack Replacement: 步骤 7 中的图像 2,2
    • Pull the camera from the connectors.
  8. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 8 中的图像 1,2 HP 7 Plus 1302 Headphone Jack Replacement: 步骤 8 中的图像 2,2
    • Identify the three T5x1mm screws and remove them with a Phillips #000
  9. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 9 中的图像 1,2 HP 7 Plus 1302 Headphone Jack Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Unplug the connector with the tweezers.
    • Remove the tape.
  10. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 10 中的图像 1,2 HP 7 Plus 1302 Headphone Jack Replacement: 步骤 10 中的图像 2,2
    • Flip the ZIF connector with the metal spudger.
    • Pull the ribbon connector out.
  11. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 11 中的图像 1,3 HP 7 Plus 1302 Headphone Jack Replacement: 步骤 11 中的图像 2,3 HP 7 Plus 1302 Headphone Jack Replacement: 步骤 11 中的图像 3,3
    • Pull the orange tape with the tweezers.
    • Flip the ZIF connector with the spudger.
    • Pull the ribbon connector with the tweezers.
  12. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 12 中的图像 1,1
    • Remove the gray tape below the ribbon connector.
  13. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 13 中的图像 1,2 HP 7 Plus 1302 Headphone Jack Replacement: 步骤 13 中的图像 2,2
    • Flip the ZIF connector.
    • Pull the ribbon connector out with the tweezers.
  14. HP 7 Plus 1302 Headphone Jack Replacement: 步骤 14 中的图像 1,2 HP 7 Plus 1302 Headphone Jack Replacement: 步骤 14 中的图像 2,2
    • Pull the circuit board off.
  15. HP 7 Plus 1302 Headphone Jack Replacement, Headphone Jack: 步骤 15 中的图像 1,1
    • Desolder the six points on the headphone jack using the soldering iron.
    • Soldering iron will be hot be careful.
    • For more instructions about how to use the Soldering iron click here.
结论
Shannon Suttles
于01/29/17注册
225 声望
创作了2篇指南
团队
IUPUI, Team 1-4, Baechle Spring 2017 IUPUI, Team 1-4, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S1G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 131
