动态照片拍摄
成为一个动作片主人公!本指南需要一些图片,这些图片能够更好演示如何进行某些特定操作。
不正确的工具
通过在图片或文字中使用正确的工具来帮助完善该指南
需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片!
简介
转到步骤 1 ↓If the device is failing to charge it may be necessary to replace the charging port. The most difficult step will be soldering the charging port, it is important to make sure you have all tools required and follow the instructions precisely.
你所需要的
工具
Spudger4.9
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Push out the battery connector using the spudger.
Swing the battery connector clear of the connector socket.
另外一个人完成了本指南。
