跳转到主内容
加入维修社区 - 创建账户
HP 7 Plus 1302 Camera Replacement
你所需要的
  1. HP 7 Plus 1302 Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Camera Replacement: 步骤 2 中的图像 1,2 HP 7 Plus 1302 Camera Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Camera Replacement: 步骤 3 中的图像 1,2 HP 7 Plus 1302 Camera Replacement: 步骤 3 中的图像 2,2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Camera Replacement, Front and Rear Facing Cameras: 步骤 4 中的图像 1,1
    • The cameras are connected together via a small ribbon cable with one electrical connection in between them.
    • Locate the small grey connector near the top of the device. Using the Spudger tool, gently pull it away from the device until it releases its connection.
    • This will come out very easily so don't use much force.
  5. HP 7 Plus 1302 Camera Replacement: 步骤 5 中的图像 1,2 HP 7 Plus 1302 Camera Replacement: 步骤 5 中的图像 2,2
    • Next move to front facing camera. Using the plastic spudger, push the small tabs out of the way while lightly pulling up on the camera.
    • There is a tab on either side of the camera that must both be released.
    • Then gently pull the camera up and away from the device.
  6. HP 7 Plus 1302 Camera Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • The rear facing camera is held down with double sided tape.
    • Using the tweezers, gently pry the rear facing camera up out of its socket.
  7. HP 7 Plus 1302 Camera Replacement: 步骤 7 中的图像 1,1
    • Lift the camera assembly away from the device to remove it.
结论
另外一个人完成了本指南。
Erik Hegg
于07/09/15注册
236 声望
撰写一个指南
团队
IUPUI, Team 1-2, Renguette SU 2015 IUPUI, Team 1-2, Renguette SU 2015 的会员
IUPUI-RENGUETTE-SU15S1G2
5 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 466
