跳转到主内容
加入维修社区 - 创建账户
HP 7 Plus 1302 Back Cover Replacement
你所需要的
  1. HP 7 Plus 1302 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Back Cover Replacement: 步骤 2 中的图像 1,2 HP 7 Plus 1302 Back Cover Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Back Cover Replacement: 步骤 3 中的图像 1,2 HP 7 Plus 1302 Back Cover Replacement: 步骤 3 中的图像 2,2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
结论
Marquies
于07/07/15注册
245 声望
撰写一个指南
团队
IUPUI, Team 1-2, Renguette SU 2015 IUPUI, Team 1-2, Renguette SU 2015 的会员
IUPUI-RENGUETTE-SU15S1G2
5 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 20
总计 1,183
