跳转到主内容
HP 17-x173dx Optical Disk Drive Replacement
你所需要的
  1. HP 17-x173dx Optical Disk Drive Replacement, Optical Disk Drive: 步骤 1 中的图像 1,1
    • Start by placing the laptop with its bottom facing up.
    • Using the Phillips #0 screwdriver, remove the single 7 mm screw that holds the disk drive in place.
  2. HP 17-x173dx Optical Disk Drive Replacement: 步骤 2 中的图像 1,2 HP 17-x173dx Optical Disk Drive Replacement: 步骤 2 中的图像 2,2
    • Use a spudger or thin item to apply outward pressure between the disk drive opening and the device to remove the optical disk drive. You may be able to remove it using your fingernail.
结论
Insert new optical drive. To reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 8
总计 229
