跳转到主内容
HP 15-f004dx Battery Replacement
你所需要的
  1. HP 15-f004dx Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
  2. HP 15-f004dx Battery Replacement: 步骤 2 中的图像 1,2 HP 15-f004dx Battery Replacement: 步骤 2 中的图像 2,2
    • Locate a switch in the upper left corner with a lock symbol next to it.
    • Slide the switch to the right until you see an unlocked symbol on the opposite side.
  3. HP 15-f004dx Battery Replacement: 步骤 3 中的图像 1,2 HP 15-f004dx Battery Replacement: 步骤 3 中的图像 2,2
    • There is another switch on the opposite side of the computer with a battery symbol next to it.
    • Slide this switch to the left and the battery should detach from the computer.
    • To completely remove the battery, simply pull the battery away from the computer.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 303
