跳转到主内容
HP 15-ef Rubber Feet Replacement
你所需要的
  1. HP 15-ef Rubber Feet Replacement, Flip your laptop over: 步骤 1 中的图像 1,1
    • Flip your laptop over so the rubber feet are facing up.
  2. HP 15-ef Rubber Feet Replacement, Peel up an end of the front foot: 步骤 2 中的图像 1,3 HP 15-ef Rubber Feet Replacement, Peel up an end of the front foot: 步骤 2 中的图像 2,3 HP 15-ef Rubber Feet Replacement, Peel up an end of the front foot: 步骤 2 中的图像 3,3
    • The rubber feet cover a total of six back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
  3. HP 15-ef Rubber Feet Replacement, Remove the front foot: 步骤 3 中的图像 1,3 HP 15-ef Rubber Feet Replacement, Remove the front foot: 步骤 3 中的图像 2,3 HP 15-ef Rubber Feet Replacement, Remove the front foot: 步骤 3 中的图像 3,3
    • Peel the front foot away from the back cover and remove it.
  4. HP 15-ef Rubber Feet Replacement, Remove the rear foot: 步骤 4 中的图像 1,3 HP 15-ef Rubber Feet Replacement, Remove the rear foot: 步骤 4 中的图像 2,3 HP 15-ef Rubber Feet Replacement, Remove the rear foot: 步骤 4 中的图像 3,3
    • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
    • Peel the rear foot away from the back cover and remove it.
  5. HP 15-ef Rubber Feet Replacement, Reassembly information: 步骤 5 中的图像 1,3 HP 15-ef Rubber Feet Replacement, Reassembly information: 步骤 5 中的图像 2,3 HP 15-ef Rubber Feet Replacement, Reassembly information: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    • Note that the rubber feet are different:
    • The rear foot is thicker, with a deeper recess.
    • The front foot is thinner, with a shallower recess.
    • During reassembly:
    • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
    • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
    • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
    • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
结论
Spencer Day
于09/14/22注册
112,772 声望
创作了811篇指南
团队
iFixit iFixit 的会员
Staff
120 名成员
创作了20,186篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 46
总计 1,471
