简介
Here is a step by step guide to remove and replace your speakers for the HP 15-bs168cl. If your laptop's speakers no longer work, are making a “crackling” sound, or unpredictably stop making sound this is the replacement guide for you. Before replacing your laptop speakers, make sure to troubleshoot your audio problems following the steps listed here. After troubleshooting your audio issues, if you are still experiencing distorted audio through your speakers follow this guide to replace them.
你所需要的
Use a Phillips #1 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
Flip the laptop over and open the screen.
Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
Flip the computer back over and remove the bottom plastic shell.
Using a Phillips #0 screwdriver remove the screw from the Wi-fi card.
Remove the card.
一条评论
If this problem cannot be solved in the software, the speaker may break on its own, or the cable inside the computer might leak. If you can find the repair manual for your PC, don't be afraid to break it and see what it is - otherwise, you can contact a specialist. If you can't guarantee this, please send it back to the manufacturer to have it fixed, or find a local store that can diagnose the problem for you. With any luck, you'll be stuck in no time.
