跳转到主内容
HP 15-bs168cl Fan Replacement
你所需要的
  1. HP 15-bs168cl Fan Replacement, Battery: 步骤 1 中的图像 1,2 HP 15-bs168cl Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug your laptop from its power adapter.
    • Turn the laptop over.
  2. HP 15-bs168cl Fan Replacement: 步骤 2 中的图像 1,2 HP 15-bs168cl Fan Replacement: 步骤 2 中的图像 2,2
    • Slide the Battery lock slider to the right until you see the “Unlocked” lock symbol.
  3. HP 15-bs168cl Fan Replacement: 步骤 3 中的图像 1,2 HP 15-bs168cl Fan Replacement: 步骤 3 中的图像 2,2
    • Slide the Battery release slider towards the battery while pulling the battery out.
  4. HP 15-bs168cl Fan Replacement, Fan: 步骤 4 中的图像 1,2 HP 15-bs168cl Fan Replacement, Fan: 步骤 4 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
  5. HP 15-bs168cl Fan Replacement: 步骤 5 中的图像 1,2 HP 15-bs168cl Fan Replacement: 步骤 5 中的图像 2,2
    • Carefully peel the four rubber feet off the bottom to reveal the four hidden screws.
    • Use a Phillips #1 screwdriver to remove the four 10.5 mm screws.
  6. HP 15-bs168cl Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the DVD drive by carefully sliding it out.
  7. HP 15-bs168cl Fan Replacement: 步骤 7 中的图像 1,3 HP 15-bs168cl Fan Replacement: 步骤 7 中的图像 2,3 HP 15-bs168cl Fan Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Flip the laptop over and open the screen.
    • Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
    • Flip the computer back over and remove the bottom plastic shell.
  8. HP 15-bs168cl Fan Replacement: 步骤 8 中的图像 1,2 HP 15-bs168cl Fan Replacement: 步骤 8 中的图像 2,2
    • Using a Phillips #1 screwdriver remove the screw from the Wi-fi card.
    • Remove the card.
  9. HP 15-bs168cl Fan Replacement: 步骤 9 中的图像 1,2 HP 15-bs168cl Fan Replacement: 步骤 9 中的图像 2,2
    • Carefully unplug the LCD connector using a plastic spudger.
  10. HP 15-bs168cl Fan Replacement: 步骤 10 中的图像 1,2 HP 15-bs168cl Fan Replacement: 步骤 10 中的图像 2,2
    • Unplug the power connector.
  11. HP 15-bs168cl Fan Replacement: 步骤 11 中的图像 1,3 HP 15-bs168cl Fan Replacement: 步骤 11 中的图像 2,3 HP 15-bs168cl Fan Replacement: 步骤 11 中的图像 3,3
    • Pull all three cables to the side to reveal the 6.7 mm screw attached to the fan.
    • Remove the screw with a Phillips #0 screwdriver.
    • Unplug the fan connector.
    • Pull out the fan carefully leaving the heatsink in place.
结论
Christian Puga
于10/18/19注册
340 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 731
