跳转到主内容
HP 15-ay114cy Screen Replacement
你所需要的
  1. HP 15-ay114cy Screen Replacement, Orient the Laptop: 步骤 1 中的图像 1,1
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Screen Replacement, Push out the Battery: 步骤 2 中的图像 1,2 HP 15-ay114cy Screen Replacement, Push out the Battery: 步骤 2 中的图像 2,2
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Screen Replacement, Remove the Battery: 步骤 3 中的图像 1,2 HP 15-ay114cy Screen Replacement, Remove the Battery: 步骤 3 中的图像 2,2
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
  4. HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: 步骤 4 中的图像 1,2 HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: 步骤 4 中的图像 2,2
    • Insert the flat end of the plastic opening tool between the screen and plastic frame.
    • Use the plastic opening tool to carefully pry the plastic frame off of the screen, starting in the middle and moving towards the corners.
  5. HP 15-ay114cy Screen Replacement, Remove the Screen: 步骤 5 中的图像 1,3 HP 15-ay114cy Screen Replacement, Remove the Screen: 步骤 5 中的图像 2,3 HP 15-ay114cy Screen Replacement, Remove the Screen: 步骤 5 中的图像 3,3
    • Use the #00 Phillips-head screwdriver to remove the four 3 mm screws in each corner and carefully detach the screen and lay it onto the keyboard.
  6. HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: 步骤 6 中的图像 1,3 HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: 步骤 6 中的图像 2,3 HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: 步骤 6 中的图像 3,3
    • Use your thumb and pointer finger to cautiously remove the display connector from the metal frame.
结论
Bradley Evans
于01/24/20注册
613 声望
创作了5篇指南
团队
S20S3G#1 S20S3G#1 的会员
Local Repair Groups
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 306
