跳转到主内容
HP 15-ay078nr RAM Replacement
你所需要的
  1. HP 15-ay078nr RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the laptop so that the underside is facing up.
    • Rotate the device so that the CD slot is in the upper left corner.
  2. HP 15-ay078nr RAM Replacement: 步骤 2 中的图像 1,2 HP 15-ay078nr RAM Replacement: 步骤 2 中的图像 2,2
    • Put your fingers on the battery latch.
  3. HP 15-ay078nr RAM Replacement: 步骤 3 中的图像 1,2 HP 15-ay078nr RAM Replacement: 步骤 3 中的图像 2,2
    • Using your fingers, push each battery latch simultaneously towards the middle.
    • This releases the battery.
    • Remove the battery from the laptop.
  4. HP 15-ay078nr RAM Replacement, Back Panel: 步骤 4 中的图像 1,2 HP 15-ay078nr RAM Replacement, Back Panel: 步骤 4 中的图像 2,2
    • Pull off the two rubber feet on the underside of the device.
    • Remove the twelve 9.5 mm screws from the underside of the device using a Phillips #2 screwdriver.
  5. HP 15-ay078nr RAM Replacement: 步骤 5 中的图像 1,1
    • Slide an opening pick around the edges between the back panel and the rest of the device to release the plastic retention clips that hold the panel in place.
  6. HP 15-ay078nr RAM Replacement: 步骤 6 中的图像 1,1
    • Lift up on the panel to remove it completely from the device.
  7. HP 15-ay078nr RAM Replacement, RAM: 步骤 7 中的图像 1,1
    • Place your fingers on the latches that hold the RAM in place.
  8. HP 15-ay078nr RAM Replacement: 步骤 8 中的图像 1,1
    • Pull the latches apart, releasing the RAM from its holder.
    • Remove the old RAM from the laptop.
结论
If the device does not work, you will need to make sure that the RAM sticks have equal measurements to each other, otherwise it will not work properly
Cameron Duffy
于10/25/21注册
327 声望
创作了3篇指南
团队
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S3G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 246
