简介
If your HP 15-af123cl’s battery is not lasting as long as it once did, or it is simply falling out, or the battery is not charging, use this guide to replace it.
The battery gives the computer power, and if it is faulty or not connected properly, it will drain fast, or simply not power the computer or charge at all.
Before starting this guide, make sure that the problem is not that your current battery is just not all the way in. Look at the steps below, and follow them, and if your battery is now working you are good to go.
Be warned it is very easy to break one of the locking pins on the battery if you use too much force, so be gentle when following this guide.
For optimal performance, after completing this guide, calibrate your newly installed battery.
2等其他人完成本指南。
