跳转到主内容
HP 14-dq5043cl SSD Replacement
你所需要的
  1. HP 14-dq5043cl SSD Replacement, Lower Case: 步骤 1 中的图像 1,2 HP 14-dq5043cl SSD Replacement, Lower Case: 步骤 1 中的图像 2,2
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Remove the two rubber feet on the lower case.
    • If you intend to reuse the rubber feet: Use a hairdryer or iOpener to lightly heat the feet to loosen the adhesive that secures them prior to removal. Take care not to stretch out the rubber.
  2. HP 14-dq5043cl SSD Replacement: 步骤 2 中的图像 1,1
    • Remove the six M2XL6 Phillips screws that secure the lower case.
  3. HP 14-dq5043cl SSD Replacement: 步骤 3 中的图像 1,3 HP 14-dq5043cl SSD Replacement: 步骤 3 中的图像 2,3 HP 14-dq5043cl SSD Replacement: 步骤 3 中的图像 3,3
    • Insert a nylon spudger into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Remove the lower case.
  4. HP 14-dq5043cl SSD Replacement, SSD: 步骤 4 中的图像 1,2 HP 14-dq5043cl SSD Replacement, SSD: 步骤 4 中的图像 2,2
    • Remove the single screw that secures the SSD with a Phillips #1 screwdriver.
  5. HP 14-dq5043cl SSD Replacement: 步骤 5 中的图像 1,3 HP 14-dq5043cl SSD Replacement: 步骤 5 中的图像 2,3 HP 14-dq5043cl SSD Replacement: 步骤 5 中的图像 3,3
    • Pull the SSD directly out of its socket to remove it.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tristan Virgo
于02/19/25注册
522 声望
创作了5篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 121
