跳转到主内容
加入维修社区 - 创建账户
GravityLight LED Replacement
你所需要的
  1. GravityLight LED Replacement, Removing the Front Panel: 步骤 1 中的图像 1,2 GravityLight LED Replacement, Removing the Front Panel: 步骤 1 中的图像 2,2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
    询问修复机器人
    添加评论
  2. GravityLight LED Replacement, Opening the Device Housing: 步骤 2 中的图像 1,1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
    询问修复机器人
    添加评论
  3. GravityLight LED Replacement, Removing the Back Panel Screws: 步骤 3 中的图像 1,1
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
    询问修复机器人
    添加评论
  4. GravityLight LED Replacement, Removing the LED Housing: 步骤 4 中的图像 1,2 GravityLight LED Replacement, Removing the LED Housing: 步骤 4 中的图像 2,2
    • Hold the LED housing in your hand, but do not separate it too far otherwise you will tear the wires.
    • Lift the LED housing away from the back panel.
    询问修复机器人
    添加评论
  5. GravityLight LED Replacement, Remove the White Gear from the LED Housing: 步骤 5 中的图像 1,2 GravityLight LED Replacement, Remove the White Gear from the LED Housing: 步骤 5 中的图像 2,2
    • Grab the outside of the large, white gear in the LED housing and pull the gear out of the housing.
    询问修复机器人
    添加评论
  6. GravityLight LED Replacement, Position the LED Housing: 步骤 6 中的图像 1,1
    • Set the LED housing flat on a sturdy surface so that the back of the LED and the wires are exposed.
    询问修复机器人
    添加评论
  7. GravityLight LED Replacement, Cut the Wires: 步骤 7 中的图像 1,1
    • Place the GravityLight's back panel aside.
    • Use the Flush Wire Cutter to cut both the purple wire and the red wire that connect to the LED.
    询问修复机器人
    添加评论
  8. GravityLight LED Replacement, Bend the LED Leads: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • Take tweezers and bend the leads (the silver wires coming out of the bulb) so that the leads are straight.
    • The straight leads will make the LED easier to take out.
    询问修复机器人
    添加评论
  9. GravityLight LED Replacement, Remove the LED: 步骤 9 中的图像 1,1
    • Flip the LED housing over.
    • Pull the LED out with tweezers.
    询问修复机器人
    添加评论
  10. GravityLight LED Replacement, Soldering the New LED: 步骤 10 中的图像 1,1
    • For reassembly: Flip the LED housing back over.
    • Put the new LED in its spot. Solder the red wire and the purple wire back onto the new leads.
    • Make sure that you pair each wire to the correct lead. If the LED still does not light, switch the wires on the leads.
    • For information on how to solder look here: 如何焊接和拆焊
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Brian Gouldsberry
于09/26/14注册
201 声望
创作了2篇指南
团队
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 的会员
CPSU-FORTE-F14S12G2
5 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 41
总计 987
