跳转到主内容
Google Pixelbook Go Battery Replacement
你所需要的
  1. Google Pixelbook Go Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Google Pixelbook Go Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Battery Replacement: 步骤 2 中的图像 1,2 Google Pixelbook Go Battery Replacement: 步骤 2 中的图像 2,2
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Battery Replacement: 步骤 3 中的图像 1,3 Google Pixelbook Go Battery Replacement: 步骤 3 中的图像 2,3 Google Pixelbook Go Battery Replacement: 步骤 3 中的图像 3,3
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Battery Replacement: 步骤 4 中的图像 1,1
    • Insert wisdom here.
  5. Google Pixelbook Go Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • If your replacement battery comes with a new cover already attached, disregard this step.
    • Use an iFixit opening tool to peel back the adhesive on the entire battery system.
    • Carefully remove battery from the base.
    • Align the new battery system with the cover and attach using adhesive or double-sided tape.
结论
Caroline Gilliard
于03/01/23注册
81 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 162
总计 1,904
