跳转到主内容
加入维修社区 - 创建账户
Google Pixel 9a Front Camera Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Google Pixel 9a Front Camera Removal, Safety precautions: 步骤 1 中的图像 1,2 Google Pixel 9a Front Camera Removal, Safety precautions: 步骤 1 中的图像 2,2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9a Front Camera Removal, Heat the rear cover: 步骤 2 中的图像 1,3 Google Pixel 9a Front Camera Removal, Heat the rear cover: 步骤 2 中的图像 2,3 Google Pixel 9a Front Camera Removal, Heat the rear cover: 步骤 2 中的图像 3,3
    • Adhesive secures the rear cover to the frame. Heating the cover softens the adhesive, making it easier to separate.
    • Use a hair dryer to heat the entire rear cover.
    • Only heat your phone so it's just hot to the touch. Extreme heat can damage the rear cover, screen, or battery.
  3. Google Pixel 9a Front Camera Removal, Apply a suction handle: 步骤 3 中的图像 1,2 Google Pixel 9a Front Camera Removal, Apply a suction handle: 步骤 3 中的图像 2,2
    • Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
  4. Google Pixel 9a Front Camera Removal, Insert an opening pick: 步骤 4 中的图像 1,3 Google Pixel 9a Front Camera Removal, Insert an opening pick: 步骤 4 中的图像 2,3 Google Pixel 9a Front Camera Removal, Insert an opening pick: 步骤 4 中的图像 3,3
    • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
    • Insert the tip of an opening pick into the gap.
  5. Google Pixel 9a Front Camera Removal, Adhesive information: 步骤 5 中的图像 1,3 Google Pixel 9a Front Camera Removal, Adhesive information: 步骤 5 中的图像 2,3 Google Pixel 9a Front Camera Removal, Adhesive information: 步骤 5 中的图像 3,3
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you separate the adhesive.
    • When separating the left and right edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
  6. Google Pixel 9a Front Camera Removal, Separate the rear cover adhesive: 步骤 6 中的图像 1,3 Google Pixel 9a Front Camera Removal, Separate the rear cover adhesive: 步骤 6 中的图像 2,3 Google Pixel 9a Front Camera Removal, Separate the rear cover adhesive: 步骤 6 中的图像 3,3
    • If you ever have trouble separating the adhesive, apply more heat and try again.
    • Slide the opening pick up the right edge, around the top right corner, and along the top edge to separate the adhesive securing the rear cover.
  7. Google Pixel 9a Front Camera Removal: 步骤 7 中的图像 1,3 Google Pixel 9a Front Camera Removal: 步骤 7 中的图像 2,3 Google Pixel 9a Front Camera Removal: 步骤 7 中的图像 3,3
    • Insert an opening pick in the initial gap you created near the center of the rear cover's right edge.
    • Slide the opening pick down the right edge, along the bottom edge, and up the left edge to separate the adhesive securing the cover.
  8. Google Pixel 9a Front Camera Removal, Separate the camera bezel adhesive: 步骤 8 中的图像 1,3 Google Pixel 9a Front Camera Removal, Separate the camera bezel adhesive: 步骤 8 中的图像 2,3 Google Pixel 9a Front Camera Removal, Separate the camera bezel adhesive: 步骤 8 中的图像 3,3
    • Insert the flat edge of an opening pick under the top of the rear cover's left edge, near the camera bezel.
    • Twist the pick and apply constant pressure to separate the adhesive around the camera bezel.
  9. Google Pixel 9a Front Camera Removal, Remove the rear cover: 步骤 9 中的图像 1,2 Google Pixel 9a Front Camera Removal, Remove the rear cover: 步骤 9 中的图像 2,2
    • Remove the rear cover.
    • If you feel resistance, go back around the perimeter of the cover and use a pick to separate any remaining adhesive.
  10. Google Pixel 9a Front Camera Removal, Remove the camera bezel: 步骤 10 中的图像 1,3 Google Pixel 9a Front Camera Removal, Remove the camera bezel: 步骤 10 中的图像 2,3 Google Pixel 9a Front Camera Removal, Remove the camera bezel: 步骤 10 中的图像 3,3
    • If the camera bezel detached from the rear cover and stayed stuck to your phone, follow this step to remove it. Otherwise, skip this step.
    • Slide an opening pick under the camera bezel and pry up to remove it.
    • Only insert the pick a few millimeters under the bezel, or you risk damaging the cameras.
    • If you're having trouble, lightly heat the camera bezel.
  11. Google Pixel 9a Front Camera Removal, Remove the wireless charging assembly screws: 步骤 11 中的图像 1,2 Google Pixel 9a Front Camera Removal, Remove the wireless charging assembly screws: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Use a Torx Plus 3IP screwdriver to remove the 16 screws securing the wireless charging assembly:
    • Thirteen 5.0 mm‑long screws
    • Three 2.2 mm‑long screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  12. Google Pixel 9a Front Camera Removal, Unclip the wireless charging assembly: 步骤 12 中的图像 1,3 Google Pixel 9a Front Camera Removal, Unclip the wireless charging assembly: 步骤 12 中的图像 2,3 Google Pixel 9a Front Camera Removal, Unclip the wireless charging assembly: 步骤 12 中的图像 3,3
  13. Google Pixel 9a Front Camera Removal, Remove the wireless charging assembly: 步骤 13 中的图像 1,2 Google Pixel 9a Front Camera Removal, Remove the wireless charging assembly: 步骤 13 中的图像 2,2
    • Remove the wireless charging assembly.
  14. Google Pixel 9a Front Camera Removal, Remove the connector cover screw: 步骤 14 中的图像 1,2 Google Pixel 9a Front Camera Removal, Remove the connector cover screw: 步骤 14 中的图像 2,2
    • Be careful not to damage the battery with your tools while disconnecting it.
    • Use a Torx Plus 3IP screwdriver to remove the 1.7 mm‑long screw securing the battery connector cover.
  15. Google Pixel 9a Front Camera Removal, Remove the battery connector cover: 步骤 15 中的图像 1,3 Google Pixel 9a Front Camera Removal, Remove the battery connector cover: 步骤 15 中的图像 2,3 Google Pixel 9a Front Camera Removal, Remove the battery connector cover: 步骤 15 中的图像 3,3
    • Use tweezers to lift and remove the battery connector cover.
  16. Google Pixel 9a Front Camera Removal, Disconnect the battery: 步骤 16 中的图像 1,2 Google Pixel 9a Front Camera Removal, Disconnect the battery: 步骤 16 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery cable press connector.
  17. Google Pixel 9a Front Camera Removal, Disconnect the front camera: 步骤 17 中的图像 1,2 Google Pixel 9a Front Camera Removal, Disconnect the front camera: 步骤 17 中的图像 2,2
    • Be very careful not to touch the camera lenses when removing the front camera. If you accidentally do, use a clean cloth to wipe them off.
    • Use the point of a spudger to pry up and disconnect the front camera press connector, prying under the top left corner.
  18. Google Pixel 9a Front Camera Removal, Remove the front camera: 步骤 18 中的图像 1,3 Google Pixel 9a Front Camera Removal, Remove the front camera: 步骤 18 中的图像 2,3 Google Pixel 9a Front Camera Removal, Remove the front camera: 步骤 18 中的图像 3,3
    • Use tweezers to grip the center of the front camera, between the press connector and the camera itself.
    • Flip the camera towards the right edge and gently peel it off the copper foil.
终点
Spencer Day
于09/14/22注册
161,656 声望
创作了1,045篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了24,061篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 60
