跳转到主内容
你所需要的
视频概述
这个拆解是不是维修指南。 要维修你的的Google Pixel 3,请使用我们的维修手册
  1. Google Pixel 3拆解, Google Pixel 3拆解: 步骤 1 中的图像 1,2 Google Pixel 3拆解, Google Pixel 3拆解: 步骤 1 中的图像 2,2
    • 拆解更新:在更大的 Pixel 3 XL 里找到了 Samsung 生产的 OLED 屏幕后,我们拆解了 Pixel 3 的屏幕后发现,它来自 LG 显示,惊喜吧!
    • 这与去年的情况完全相反,Pixel 2 使用 Samsung 的面板时,它更大的兄弟用的屏幕来自 LG。
    • 有传言称 LG 一直在努力提升它的 OLED 技术——我们很好奇他们今年新的屏幕表现如何。
  2. 最后的想法
    • 全机仅使用标准T3梅花螺丝。
    • 电池使用维修友好型易拉胶固定
    • 为了防水而使用的O型垫圈和粘合剂对维修而言增加了难度,但同时减少了因为进水而需要维修的可能
    • 屏幕维修相较前几代而言难度上升,你需要完全拆解才能更换屏幕
    • 对于任何维修你都必须要处理背板的粘合剂(事后还要重新粘合)
    • 双面的玻璃意味着跌落时更有可能损坏
    可修复性评分
    4
    可修复性10分中得4分
    (10是最容易修复)
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
15条评论
Is the pixel 3 display supplied by Samsung like the pixel 3 xl?
Max Ulloa - 回复
I’m sure they would have mentioned if it was not.
Milan Cosovic -
Sorry for the delay! The Pixel 3 model we got actually had a LG display! We’ve updated the teardown to reflect this.
Arthur Shi -
The Pixel 3 and 3XL phones have LG's POLED displays
madgear2707 -
Can you share the manufacturer of the display?
John Huffaker - 回复
Sorry for the delay! The Pixel 3 model we got actually had a LG display! We have updated our teardowns to reflect this.
Arthur Shi -
In person at a Verizon store the pixel 3xl colors are almost identical to note 9. But the 3 colors are off. Tested 3 locations same result. Not sure if the demo modes are using different saturation or not.
Brian Schumaker - 回复
The loudspeakers or Pixel 3 are the same (or at least have same Power) or Pixel 3XL?
Arthur Schnitzler - 回复
I noticed it was little louder toward the bottom of the xl. Like your a bit off center when watching a video.
Brian Schumaker -
Is there no proximity sensor?
C SUN - 回复
Do you really have to completely tear down the device to replace the screen? Seems like the locations of the connectors wouldn’t necessarily require you to take out the motherboard if you’re just going to be pulling the screen off of the frame, but it’s hard to tell from this tear-down.
FixNcell Phone Repair - 回复
I second, what FixNcell Phone Repair wrote: How exactly do I seperate the display from the frame? The Teardown video doesn’t show that. I assume that I have to heat up the screen and work my way through some adhesive…? Haven’t found a video where that part is shown.
Georg Bill - 回复
Would i be able install more RAM onto the board?
Roman Baca - 回复
I want to replace wifi/Bluetooth module in pixel 3xl, does pixel 3 boad have the same wifi/Bluetooth module as pixel 3xl?
Dr. Abdullah Aurangzaib - AAZ - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 54
过去 30 天: 250
总计 82,286
