仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
在这个步骤中使用的工具:
Magnetic Project Mat
$19.95
购买
Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
Remove the following screws securing the midframe:
Eleven 3.7 mm Phillips screws
One 4 mm T5 Torx screw
Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from.
Lift the midframe up starting from the bottom edge.
When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone.
As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
Ennis正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
