跳转到主内容
Google Pixel 2 Midframe Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Google Pixel 2 Midframe Replacement, Midframe: 步骤 1 中的图像 1,1
    • Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
  2. Google Pixel 2 Midframe Replacement: 步骤 2 中的图像 1,2 Google Pixel 2 Midframe Replacement: 步骤 2 中的图像 2,2
    • Slide the point of a spudger under the proximity sensor cable, starting from the side closest to the front-facing camera.
    • Gently lift the edge of the sensor cable until the sensor is perpendicular to the midframe.
  3. Google Pixel 2 Midframe Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
    • Remove the following screws securing the midframe:
    • Eleven 3.7 mm Phillips screws
    • One 4 mm T5 Torx screw
  4. Google Pixel 2 Midframe Replacement: 步骤 4 中的图像 1,2 Google Pixel 2 Midframe Replacement: 步骤 4 中的图像 2,2
    • Insert an opening tool into the notch in the midframe near the hold button.
    • Pry the midframe up enough to create a gap between it and the phone case. The midframe cannot yet be completely removed.
  5. Google Pixel 2 Midframe Replacement: 步骤 5 中的图像 1,3 Google Pixel 2 Midframe Replacement: 步骤 5 中的图像 2,3 Google Pixel 2 Midframe Replacement: 步骤 5 中的图像 3,3
    • Lift the midframe up starting from the bottom edge.
    • When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone.
    • As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
结论
Adam O'Camb
于04/11/15注册
197,108 声望
创作了416篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 94
