跳转到主内容
Goal Zero Rock Out 2 #94007 Speaker Repair
你所需要的
  1. Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 1 中的图像 1,3 Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 1 中的图像 2,3 Goal Zero Rock Out 2 #94007 Speaker Repair, Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 1 中的图像 3,3
    • Power off your speaker before beginning disassembly.
    • Use a 2 mm Allen Key to remove eight 13 mm screws from the faceplate.
    • Use a spudger to remove the faceplate and set it aside.
  2. Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 2 中的图像 1,3 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 2 中的图像 2,3 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 2 中的图像 3,3
    • Remove the gray center piece and yellow rubber lining.
  3. Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 3 中的图像 1,3 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 3 中的图像 2,3 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 3 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove four 12 mm screws from the speaker body.
    • Unzip the speaker case.
    • Turn the the speaker over so the bottom is facing up.
  4. Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 4 中的图像 1,3 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 4 中的图像 2,3 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 4 中的图像 3,3
    • Remove speaker from cloth case.
  5. Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 5 中的图像 1,2 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 5 中的图像 2,2
    • Hold the speaker and gently separate the two parts.
    • Don't yank or pull it apart as the two halves are connected by cables.
  6. Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 6 中的图像 1,3 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 6 中的图像 2,3 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 6 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the four 12 mm screws securing the center resonator.
    • Carefully remove center resonator from the enclosure.
  7. Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 7 中的图像 1,3 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 7 中的图像 2,3 Goal Zero Rock Out 2 #94007 Speaker Repair: 步骤 7 中的图像 3,3
    • This step requires soldering. Soldering can cause injuries such as burns to the skin. It can also produce fumes that are harmful so working in a well-ventilated area is advised.
    • Use wire strippers to remove about 6 mm of insulation from the detached speaker wire.
    • Set the soldering iron to 350 degrees.
    • Add solder to the tip of the iron and then touch the tip to exposed wire.
    • Join the wire with the electrical contact on the speaker.
结论
Ricardo Arevalo Castaneda
于03/05/24注册
157 声望
撰写一个指南
团队
CSU Los Angeles, Team 8-6, Grodsky Spring 2024 CSU Los Angeles, Team 8-6, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S8G6
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 43
总计 667
