跳转到主内容
加入维修社区 - 创建账户
GoPro Hero4 Silver Front Panel Replacement
你所需要的
  1. GoPro Hero4 Silver Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,3 GoPro Hero4 Silver Front Panel Replacement, Front Panel: 步骤 1 中的图像 2,3 GoPro Hero4 Silver Front Panel Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
    • The seven plastic tab locations are marked in red.
    • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
    • There may be glue holding the camera face on to the housing. Be careful not to flex the camera face too much, or it will crack.
结论
15等其他人完成本指南。
Zack Hoover
于08/27/15注册
1,109 声望
创作了3篇指南
团队
USF Tampa, Team 2-1, Blackwell Fall 2015 USF Tampa, Team 2-1, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G1
4 名成员
创作了20篇指南
2指南评论
Am I mistaken, or are there missing steps in this guide?
Tom Fox - 回复
Looks like a simple remove/replace guide. Only one step needed.
justincarver - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 46
总计 12,183
