简介
The front case of your GoPro is constantly being subjected to potentially dangerous obstacles: trees, bears, viking ships, and who knows what else. Should you happen to crack or break the front case, you can replace it with a brand new one.
你所需要的
Place your thumb on the indentation in the back case on the side of the GoPro.
Gently press down with your thumb and lift the back cover away from the case to remove it.
Slide a plastic opening tool between the battery and the rear case.
Gently pry the battery up and out of the rear case.
Remove the four Phillips #00 screws securing the rear case to the rest of the device:
Two 5.5 mm coarse thread screws.
Two 4.4 mm fine thread screws.
Remove the three screws securing the motherboard assembly to the front case:
Two 10.8 mm Phillips #00 screws.
One 4.8 mm Phillips #00 screw.
5等其他人完成本指南。
