跳转到主内容
GoPro HD Hero2 Front Case Replacement
你所需要的
  1. GoPro HD Hero2 Front Case Replacement, Back Cover: 步骤 1 中的图像 1,2 GoPro HD Hero2 Front Case Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Place your thumb on the indentation in the back case on the side of the GoPro.
    • Gently press down with your thumb and lift the back cover away from the case to remove it.
  2. GoPro HD Hero2 Front Case Replacement, Battery: 步骤 2 中的图像 1,2 GoPro HD Hero2 Front Case Replacement, Battery: 步骤 2 中的图像 2,2
    • Slide a plastic opening tool between the battery and the rear case.
    • Gently pry the battery up and out of the rear case.
  3. GoPro HD Hero2 Front Case Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the case.
  4. GoPro HD Hero2 Front Case Replacement, Rear Case: 步骤 4 中的图像 1,1
    • Remove the four Phillips #00 screws securing the rear case to the rest of the device:
    • Two 5.5 mm coarse thread screws.
    • Two 4.4 mm fine thread screws.
  5. GoPro HD Hero2 Front Case Replacement: 步骤 5 中的图像 1,2 GoPro HD Hero2 Front Case Replacement: 步骤 5 中的图像 2,2
    • Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
    • Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
  6. GoPro HD Hero2 Front Case Replacement: 步骤 6 中的图像 1,2 GoPro HD Hero2 Front Case Replacement: 步骤 6 中的图像 2,2
    • Grasp the rear case and lift it off of the front case.
    • Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
  7. GoPro HD Hero2 Front Case Replacement: 步骤 7 中的图像 1,2 GoPro HD Hero2 Front Case Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
    • Be careful that you are prying on the locking tab, and not the connector itself.
    • Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
  8. GoPro HD Hero2 Front Case Replacement: 步骤 8 中的图像 1,3 GoPro HD Hero2 Front Case Replacement: 步骤 8 中的图像 2,3 GoPro HD Hero2 Front Case Replacement: 步骤 8 中的图像 3,3
    • Lift the speaker out of the rear case with the tip of a spudger.
    • Remove the rear case.
  9. GoPro HD Hero2 Front Case Replacement, Motherboard Assembly: 步骤 9 中的图像 1,1
    • Remove the three screws securing the motherboard assembly to the front case:
    • Two 10.8 mm Phillips #00 screws.
    • One 4.8 mm Phillips #00 screw.
  10. GoPro HD Hero2 Front Case Replacement: 步骤 10 中的图像 1,2 GoPro HD Hero2 Front Case Replacement: 步骤 10 中的图像 2,2
    • Gently grab the edges of the motherboard assembly and lift it out of the front case.
  11. GoPro HD Hero2 Front Case Replacement, Front Case: 步骤 11 中的图像 1,1
    • The front case remains.
结论
3等其他人完成本指南。
David Hodson
于04/13/10注册
150,580 声望
创作了127篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 7,033
