跳转到主内容
Gigabyte P34G Hard Drive Replacement
你所需要的
  1. Gigabyte P34G Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
    • There are three different sized screws.
    • 1x 9.8mm Screw
    • 8x 5.6mm Screws
    • 6x 5.0mm Screws
    • Divide the screws by size and save them in a safe space for reassembly later.
  2. Gigabyte P34G Hard Drive Replacement: 步骤 2 中的图像 1,2 Gigabyte P34G Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Carefully peel back the two pieces of black tape holding down the cord.
    • Pull the marked tab straight up away from the board to disconnect the hard drive from the board.
  3. Gigabyte P34G Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Carefully lift the hard drive for removal.
结论
另外一个人完成了本指南。
yeunghayden
于05/01/15注册
841 声望
创作了6篇指南
团队
Cal Poly, Team 8-1, Regan Spring 2015 Cal Poly, Team 8-1, Regan Spring 2015 的会员
CPSU-REGAN-S15S8G1
5 名成员
创作了12篇指南
一条评论
Hi.
Can you please show me how to remove the back cover on the gigabyte sabre 17 laptop?
Need to change the hdd but cannot open the back.
Thank you.
Rizwan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 3,379
