跳转到主内容
GermGuardian AC4825E UV-C Bulb Replacement
你所需要的
  1. GermGuardian AC4825E UV-C Bulb Replacement, HEPA Filter Unit: 步骤 1 中的图像 1,1
    • Check if the purifier's power cord is plugged into an electrical outlet.
    • If it is plugged in, unplug the power cord.
  2. GermGuardian AC4825E UV-C Bulb Replacement: 步骤 2 中的图像 1,2 GermGuardian AC4825E UV-C Bulb Replacement: 步骤 2 中的图像 2,2
    • Grab the rear cover of the purifier with one finger on the Lock and Release button.
    • Press the button down, and pull the rear cover away from the purifier.
  3. GermGuardian AC4825E UV-C Bulb Replacement: 步骤 3 中的图像 1,3 GermGuardian AC4825E UV-C Bulb Replacement: 步骤 3 中的图像 2,3 GermGuardian AC4825E UV-C Bulb Replacement: 步骤 3 中的图像 3,3
    • Use your hands to pull the HEPA filter out of the purifier.
    • After reassembly, push & hold the UV control button for 5 seconds to reset the filter change indicator.
  4. GermGuardian AC4825E UV-C Bulb Replacement, UV-C Bulb: 步骤 4 中的图像 1,1
    • Remove the two screws from the metal UV-C shield by turning the screws counter-clockwise using a Phillips #00 screwdriver.
    • Grab and pull the UV-C shield away from the purifier to remove it.
  5. GermGuardian AC4825E UV-C Bulb Replacement: 步骤 5 中的图像 1,3 GermGuardian AC4825E UV-C Bulb Replacement: 步骤 5 中的图像 2,3 GermGuardian AC4825E UV-C Bulb Replacement: 步骤 5 中的图像 3,3
    • Using a tissue or a clean cloth, reach into the exposed space and grab the UV-C bulb.
    • Pull the UV-C bulb out of the exposed space to remove the bulb from its socket.
    • After reassembly, press and hold the UV control button for 5 seconds to reset the UV bulb change indicator.
结论
另外一个人完成了本指南。
Tim Lourenco
于03/28/22注册
305 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-1, Mellen Spring 2022 UMass Dartmouth, Team 2-1, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S2G1
4 名成员
创作了2篇指南
一条评论
you end after you pull the bulb out. do you put another bulb in (of course) is there a right/wrong way (which side up or down) then do you plug it back in prior to holding the uv button 5 seconds? do you turn it on prior to holding the uv button 5 seconds? Please explain in detail what I should do.
william estes - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 78
总计 1,938
