跳转到主内容
GermGuardian AC4825E HEPA Filter Unit Replacement
  1. GermGuardian AC4825E HEPA Filter Unit Replacement, HEPA Filter Unit: 步骤 1 中的图像 1,1
    • Check if the purifier's power cord is plugged into an electrical outlet.
    • If it is plugged in, unplug the power cord.
  2. GermGuardian AC4825E HEPA Filter Unit Replacement: 步骤 2 中的图像 1,2 GermGuardian AC4825E HEPA Filter Unit Replacement: 步骤 2 中的图像 2,2
    • Grab the rear cover of the purifier with one finger on the Lock and Release button.
    • Press the button down, and pull the rear cover away from the purifier.
  3. GermGuardian AC4825E HEPA Filter Unit Replacement: 步骤 3 中的图像 1,3 GermGuardian AC4825E HEPA Filter Unit Replacement: 步骤 3 中的图像 2,3 GermGuardian AC4825E HEPA Filter Unit Replacement: 步骤 3 中的图像 3,3
    • Use your hands to pull the HEPA filter out of the purifier.
    • After reassembly, push & hold the UV control button for 5 seconds to reset the filter change indicator.
结论
Tim Lourenco
于03/28/22注册
305 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-1, Mellen Spring 2022 UMass Dartmouth, Team 2-1, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S2G1
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 29
总计 412
